Insteon Wireless Relay?
Hello
Can anyone let me what Wireless Relays are available that will communicate with the ISY? Also Is their an Analog Input that will communicate with the ISY? Low Voltage is good!
I have a number of uses for this in my home.
Thank you!
Bill
Wireless Relay?
You want RF or over power lines by Insteon signals?
I have not seen any RF types relays but there are a few Insteon power line ones.
The Insteon I/OLinc has a form C {NC and NO} dry contact relay in it and a closer to digital input than analog input.
Simplehomenet makes a few Insteon modules that are different combinations of I/O. Some have all inputs some all outputs and some a mixture. Theirs have a few of the inputs configurable to analog or digital inputs. Zero to five volts sound like it.
http://www.smarthome.com/2450/IOLinc-IN ... ut-/p.aspx
http://www.smarthome.com/_/Automatic_Sp ... r/nav.aspx
http://www.simplehomenet.com/cats.asp?id=12
There are links on all the above sites to find users manuals for the modules. If you care to read about them.
If you need an RF device that sends an On or Off when a magnet or dry contact is moved. There is a TriggerLinc.
http://www.smarthome.com/2421/TriggerLi ... sor/p.aspx
