Can't set buttons toggle mode
So my adventure continues ...
I'm trying to set toggle mode to non-toggle on on some buttons of a keypad 8 but so far haven't been able to. I always get a request failed. If I then go back to try and change it again, it shows the buttons as non-toggle off.
This is the event viewer dump when I select non-toggle on
Thu 01/20/2011 10:13:34 AM : [All ] Writing 1 bytes to devices
Thu 01/20/2011 10:13:34 AM : [16 79 ED 1 ] Memory : Write dbAddr=0x0249 [82]
Thu 01/20/2011 10:13:34 AM : [iNST-ACK ] 02 62 16.79.ED 1F 2E 00 01 08 82 00 00 00 00 00 00 00 00 00 00 00 06 (00)
Thu 01/20/2011 10:13:35 AM : [iNST-SRX ] 02 50 16.79.ED 13.20.53 2B 2E 00 (00)
Thu 01/20/2011 10:13:35 AM : [standard-Direct Ack][16.79.ED-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
BTW, I'm running v2.8.10 on the isy and this is a 2486D 8-button v.36
-Julio
Button B on KPL-8. Going from toggle to non-toggle-on.
I ran this test on an 8 button B v33 but I would have thought they would be the same. As you can see from the Memory : Write entry an 02 is being written here where you have an 82. Since your trace shows an ACK it appears the device accepted the command. Are you sure you are running on the 2.8.10 Admin Console. Try invoking the Admin Console directly from the UDI web site.
Thu 01/20/2011 11:17:05 AM : [All ] Writing 1 bytes to devices
Thu 01/20/2011 11:17:05 AM : [b 4A AD 1 ] Memory : Write dbAddr=0x0249 [02]
Thu 01/20/2011 11:17:05 AM : [iNST-ACK ] 02 62 0B.4A.AD 1F 2E 00 01 08 02 00 00 00 00 00 00 00 00 00 00 00 06 (00)
Thu 01/20/2011 11:17:06 AM : [iNST-SRX ] 02 50 0B.4A.AD 12.9F.E4 2B 2E 00 (00)
Thu 01/20/2011 11:17:06 AM : [standard-Direct Ack][0B.4A.AD-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Ok, I invoked the console from the UDI site. I selected the 8-keypad B button. Clicked on Toggle On/Off. Selected "On For Non-toggle On", and got a "No Network Connection" dialog.
Closed the dialog. Clicked Toggle On/Off again, and the button shows as "Non-toggle [Off]".
I repeated the process and got "Request failed". Between iterations, the button alternates states from non-toggle off to toggle. Never non-toggle on.
I'm at a loss ... No clue anymore what to do.
Hello jp5150,
Are you having any other issues accessing the KPL?
Would you please try this link to the ISY: http://www.universal-devices.com/99i/2.8.10/admin.jnlp
Rand
Ok, tried the link, and unfortunately got the same result. First try at setting non-toggle on, I get a "no network" dialog. I exit, go back to try again, and the button shows a state of non-toggle off. I then select non-toggle again, and the "request failed" dialog pops up. The button then shows a status of toggle.
I'm not aware of any other issues with this KPL. It triggers its scenes correctly, and responds to programs correctly.
-Julio
jp5150
Have you been clearing the Java Cache before invoking the Admin Console from the UDI server?
Also use Help | About and confirm it shows 2.8.10.
EDIT; have you tried the actual KPL button. It takes at least one button press to get the button into non-toggle mode specified. The display is clearly wrong but perhaps it actuall did place the button in non-toggle On mode.
Lee
I just tried and in fact the buttons are in non-toggle On mode.
I still get the "no network" error the first time I try to change it, and then "request failed" everytime after that, so something is definitely screwy in my system.
Oh, and I did clear the Java cache, and I'm definitely running 2.8.10
jp5150
That is good news about the KPL button actually being configured despite the error messages and display that shows non-toggle Off. I ran a test on my system earlier and realized that your setting a value 82 versus my setting a value of 02 was because I was setting only button B and from the 82 it would indicate both button B and button H are in non-toggle On mode.
The following trace on my system now shows the same 82 because I also put button H into non-toggle ON mode.
Fri 01/21/2011 07:36:15 PM : [b 4A AD 1 ] Memory : Write dbAddr=0x0249 [82]
Fri 01/21/2011 07:36:15 PM : [iNST-ACK ] 02 62 0B.4A.AD 1F 2E 00 01 08 82 00 00 00 00 00 00 00 00 00 00 00 06 (00)
Fri 01/21/2011 07:36:16 PM : [iNST-SRX ] 02 50 0B.4A.AD 12.9F.E4 2B 2E 00 (00)
Fri 01/21/2011 07:36:16 PM : [standard-Direct Ack][0B.4A.AD-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
With all the Insteon traffic being the same and the KPL actually being set correctly, I'm wondering about the Java level. I am running 1.6.0_22-b04 on a Windows XP system.
Lee
Lee,
I'm running Java version 6 build 1.6.0_23-b05.
Late last night I decided to remove the KPL from the Isy and manually reset it. I then added it back to the Isy and I was able to configure the state of the buttons without any of the error messages.
This morning, since the KPL is finally working, I finished the scenes that include it. Now it appears I have communication issues. :x I have a feeling I'm going to have to start another thread soon regarding this.
Thanks for your help troubleshooting. Your time and patience is very much appreaciated.
-Julio
