February 1, 201115 yr Hi Everyone, I am proud to announce that MobiLinc HD for the iPad has been submitted to Apple for approval with an anticipated February release! Thank you to everyone who worked on the beta releases and all the valuable input over the last month. Check out these first look MobiLinc HD screenshots: http://www.facebook.com/MobiLinc MobiLinc HD Features: - Real Device Interaction. Interact with your devices and scenes by tapping the switch, KeypadLinc, thermostats, IOLinc, etc, on or off. Double-tap the switch interface for Fast On/Off or press and hold to dim/brighten the device or scene. - Devices that are controllers of a scene will drive the scene on/off levels when controlled via MobiLinc HD on iPad. No more devices out of sync with their scenes. - Tap KPL buttons to activate/deactivate/brighten/dim scenes. - Device/Scene/Program filters. See only what you want to see. Filter to see what's on, off, or running. - Touch Note. Turn the home screen into a notepad. Using your finger leave a message for a loved one or note. Clear by using two fingers or shake the iPad. - Tag devices, scenes, programs as favorites and access this set from My Favorites. - Weather support (ISY Only). - Multiple Profile Support. Change or add profiles by tapping on the profile name. - Supports all iOS devices from version 3.1 to current. When running MobiLinc HD on the iPhone/touch, MobiLinc HD operates as MobiLinc Pro. - Supports the ISY 26/99 line of controllers, SmartLinc, and PowerLinc controllers. Wes
February 5, 201115 yr If I purchase Resource Manager now for iPhone use will I also be able to use it in the iPad version or will I need to rebuy it? It sounds like using it now in Pro won't let me use it in HD, but waiting to buy it in HD would let me use it on my iPad and iPhones (since HD will run on my phones). Correct?
February 6, 201115 yr Author Hi, Currently no. There isn't a way to transfer in-app purchases from one app to another app. To Apple and iTunes, Resource Manager on the iPhone is different from Resource Manager on the iPad, even though these are the same plug-ins. If you wait for MobiLinc HD and purchase Resource Manager in the HD version you can install and run MobiLinc HD plus Reaource Manager on all of your iOS devices. MobiLinc Pro will continue to be iPhone/Touch only for those that don't have an iPad. Wes
