set ControLinc button status to ON
Ok I have 2 x 2430 ControLinc's
on both units I want button #5 OFF to do goodnight mode. Lee suggested to take button 5 out of scene (i did). I made a program to test how they BOTH would react.
Program:
Status 'ControlLincA-5' is OFF
Or
Status 'ControlLincB-5' is OFF
set 'Master Light' OFF
No Action
Now if A presses 5 OFF.. then Master Light will go OFF
if B presses ON then Master Light will go ON (with another rule)
Later that day if A presses OFF.. nothing will happen as it's already OFF.
So how do i change the status of a controLinc's button or how do I go about having two ControLinc's doing a good night mode if the other controler does the good morning mode (5 ON)?
thank-you in advance.
Hello detrotdr,
I would think changing status to control would do the trick.
Control 'ControlLincA-5' is Switched OFF
Or
Control 'ControlLincB-5' is Switched OFF
No Action
Tim
Tim, I agree..however I don't see how to change the status of a controLinc in the console... you can only see it under the IF.. but under the THEN.. there is nothing.
detrotdr,
Tim was suggesting you replace the IF statements in your program. You currently have:
Or
and Tim is suggesting you change those to read:
Or
Using the Control trigger will run the program each time you press OFF, while using Status will only run the program if the state changes from On to Off.
