Problem Accessing Administration Console from Macbook Pro
When accessing the Administrative Console using URL http:///admin using Firefox on my MacBook pro with Mac OS X v 10.5.8 I get the following status message at the bottom of Firefox: "Applet com.universaldevices.client.ui.UDClientApplet notloaded". I can successfully access the console via URL http///admin.jnlp.
I am running Insteon_UD99 v.2.8.16 and my product is ISY 99i/IR (1030).
Per Java.... Below is a dump from the Java console. Java version 1.6 64 bit (SE 6 64-bit 1.6.0_22-b04-307) is the first priority in my Java Preferences window. But it looks like it runs version 1.5. Just so you know, "Keep temporary files for faxt access:" is checked, I have 1,000 MB of cache and I've repeatedly have removed and re-added certificates and cleared the cache.
How can I get the applet working?
Steve
Java Dump below:
Java Plug-in 1.5.0
Using JRE version 1.5.0_26 Java HotSpot Client VM User home directory = /Users/Me
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
MRJ Plugin for Mac OS X v1.0.1
[starting up Java Applet Security @ Sat Feb 19 07:31:07 CST 2011]
java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:676)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:
124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at sun.applet.AppletClassLoader.findClass(AppletClassLoader.java:173)
at java.lang.ClassLoader.loadClass(ClassLoader.java:317)
at sun.applet.AppletClassLoader.loadClass(AppletClassLoader.java:145)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at sun.applet.AppletClassLoader.loadCode(AppletClassLoader.java:659)
at sun.applet.AppletPanel.createApplet(AppletPanel.java:786)
at sun.plugin.AppletViewer.createApplet(AppletViewer.java:1873)
at jep.AppletFramePanel.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(AppletPanel.java:715)
at sun.applet.AppletPanel.run(AppletPanel.java:369)
at jep.AppletFramePanel.run(Unknown Source)
at java.lang.Thread.run(Thread.java:655)
124)
Just a followup. I didn't have the OS version 1.6.x on my Macbook Pro and will see if that corrects the problem...
Applying the OS and software updates to get to OS x v 10.6.6 took care of my problem.
Steve
