Convert Existing Keypad from 6 to 8 key..
This is an easy one..
I have an existing KeyPad configured in 6 key mode, I want to change it for 8 Key Mode. How will ISY handle this change? do I need to Unlink the Keypad before and relink it after? Do I Need to remove it from every scene before?
Or can I simply change it and ISY will find the additional Button ?
I never removed or changed a device, so I want to be sure I don't break anything.. :)
You need to Delete the device from the ISY, change the button mode from 6 to 8, then add it back to the ISY. The Delete will automatically remove the KeypadLinc from Programs and Scenes. The KeypadLinc will have to be added back to Programs and Scenes after adding in back to the ISY.
