Residual X10 in the Logs
I am trying to troubleshoot some other issues I am having with the switches not reporting back their state to the ISY unless a query is run (but that is in another thread). When I ran a log, I saw that I, as recently as the last 24 hours, had several instances of X10 activity. Although I started as an X10 system and slowly switched over first to a hybrid system and then to an insteon-exclusive system, I am wondering what these X10 actions can be and if they are affecting my current setup. I don't see anything in my ISY admin console having to do with X10 so I am wondering if anyone has any ideas how I can research this further. I still have a few X10 switches installed but they are only connected to power (not to any devices) and are not being used. I wouldn't mind removing all X10 from my ISY setup. Thx.
Are you sure you don't still have a CM11a or CM15a or x10 HawkEye or Eagle Eye battery-operated motion detector hidden away in an unused corner or closet somewhere? How about x10 floodlights with motion detectors? Are any of your neighbors using x10 controls?
Definitely no motion sensors or floodlights. I have no idea if my neighbors use x10. As for any other devices, I am not 100% sure but I don't think I have anything else besides the old model 4 toggle wall switches. Any other way to check?
Do you have any X10 Repeaters or older Smarthome BoosterLincs or X10 SwitchLincs with BoosterLinc features?
Older BoosterLincs and SwitchLincs with BoosterLinc technology are know problems. Including communications interference.
