IRLinc Transmitter
I've added 12 IRLinc TX devices to ISY following ISY console onscreen instructions. It appears that the resulting IRLinc TX devices must be added to a scene and then that scene must be turned On for the IR command to be issued. Is this correct or can the IR command be issued for on and/or off command ... or am I missing details on how this works.
hart2hart
Yes, that is the method. If you select an IRLinc TX node there are not buttons at the bottom of the Admin Screen to issue Insteon Direct commands. The IRLinc TX responds to Scene commands. When an Insteon Controller is linked to the IRLinc TX, such as a KeypadLinc button, the KPL button only sends Scene (Group) commands.
Lee
