8 Button KeypadLinc
I just added 8 button keypadlinc. I want three buttons to follow the state of 3 programs corresponding. My thought was to turn the button on in the then branch and turn it off in the else branch. Please clue me in as to the nomenclature of Insteon command action for keypadlinc buttons with format of:
On 99 / Off 99 (Backlight Level)
hart2hart
The Backlight sets the KeypadLinc backlight LED level. It does not set the button LED ON/OFF.
To turn a KeypadLinc Secondary button LED On/Off define an ISY Scene and assign a KeypadLinc Secondary button as a Responder to the Scene. In the Program Set Insteon "scene name" ON or OFF to turn the KeypadLinc Secondary button ON or OFF.
Lee
Okay Thanks.
I also want the button to run the then or else branch of the program to set its state. How do I do this without infinite loop? My first thought was make KPL button a controller instead of responder but I think this would create loop issue.
hart2hart
To have a Program triggered by a KeypadLinc button press add an
If Control keypadlinc-button is ON
And Control keypadlinc-button is not OFF
The On button press runs the Then, the Off button press runs the Else
Turning the KPL LED On/Off with a Program does not generate a button Control event so no loop issue.
Lee
