Link SL to LampLinc using FastOn/FastOff
Hi,
Happy New Year!
I'm wondering if it's possible for the ISY to turn on/off a lamplinc whenever a FastOn/FastOff is detected from a nearby switchlinc?
Chris
Chris,
You can do this with a simple program on the ISY.
       Control 'Kitchen Fan Switch' is switched Fast On
   And Control 'Kitchen Fan Switch' is not switched Fast Off
       Set 'Kitchen Fan' On
       Set 'Kitchen Fan' Off
Substitute your devices and it should work fine. Of course, If you have a local load on the switch it will activate also.
Good Luck,
-jeff
Thanks for this code Jeff! I was currently doing my fast on/off triggers with 2 separate programs. Didn't realize I could do it with 1.
Sure! This may be the only case where one is better than two. :D
