Using a 12v trigger from a projector
Hi, I'd like to use the 12v power-on trigger from my Panasonic projector to turn on a "Now Showing..." light. I get how to turn on the light, but I have a question on the triggering.
What device do I need to sense the on/off 12v trigger from the projector? A 2450 IO Linc?
The 2450 I/OLinc can not be triggered by a 12 volt signal.
It needs a closure between the S Sensor Terminal and the GND terminal.
Smarthome does have a Low Voltage Detector Kit. That includes the I/OLinc and a Low Voltage Detector. That should work.
Unfortunately it is showing out of stock.
http://www.smarthome.com/24950A4/I-O-Li ... Kit/p.aspx
I have used an Optoisolator to trigger an I/OLinc if you care to create a small interface board to connect to it.
A 12 volt relay could be made to work also. As long as you can determine the safe current the 12 volt signal can provide.
An I/O Linc Sensor requires GND to activate the sensor. The projector trigger could be hooked to a 12V relay. Then use the relay contacts to apply GND to the I/O Linc Sensor. Do not know if the projector trigger can energize a relay. The projector spec's should provide that answer.
An alternative would be to use a Simplehomenet EZIO2X4. It has opto=isolated Inputs which will trigger with clean 12V DC. Again it depends on what the projector 12V trigger really is.
The I/O Linc would be the less expensive approach if the projector trigger will energize a relay.
Thanks guys! I mis-read the manuals, and was quite surprised when I found 5v across the GND and S terminals.
I'll look into the relay or optoisolator approach and give it a go.
You are welcome.
Calling the Input a Sensor may have not been the best choice.
I keep forgetting the some of the Simplehomenet modules have isolated inputs. :oops:
