Keypadlinc disable off LED in ISY?
edentel
Is there any way to disable the main Off LED on a 6 button KeypadLinc from within ISY?
I've had a pair of KeypadLincs setup this way for years. I had to do a reset after a recent storm. When I try the 10-5-5 button press the off button stays the same and the on button goes into a left-right toggle. I can actually see it turning on and off depending on which side of the button I press.
I tried the toggle section under the KeypadLinc in ISY but it appears to affect the both buttons rather than disabling the LED.
The are both old rev1.5 KeypadLincs
Any pointers appreciated!
-Ed
Hello Ed,
After setting the kpl on/off button node to Toggle Off did you press the kpl On button then press the Off button. I noticed that when changing back to non toggle mode the changes occured right away but when I set my kpl back to toggle off I had to cycle the on/off buttons once. Then the off button did not illuminate any longer.
Tim
      37.1k
      371.5k
