How to make a light "Blink"
I have a kitchen light controlled by an Insteon relay switch. I have this linked to an Insteon In-Line Linc with Sense in a motion sensor floodlight. How can I write a program to make the kitchen table light "Blink" when the status of the In-Line Linc is on. I heard that it requires a program to call another program for this to work.
The two programs below will do it. But you can't have the kitchen table linked to the in line device. Let ISY turn it on and off.
Blink
       Set 'Kitchen table' On
       Wait  5 seconds
       Run Program 'blink' (Else Path)
       Set 'Kitchen table' Off
       Wait  5 seconds
       Run Program 'blink' (Then Path)
Run Blink
       Status  'in line linc' is not Off
       Stop program 'blink'
WOW.......It worked. Thank you very much for your help on this. I am sort of a "newbe" and not a programer. Your instructions were easy to follow.
Thanks you again.
Jim Blackston
