Cannot link RemoteLinc2
I have upgraded my ISY-99i to firmware 3.1.10 and I'm having problems linking my RemoteLinc 2. I get the following error messages:
Node not added - failed removing links (1C 22 61 1) [-200000/-9]
Failed writing the high water mark [-200000/-1]
I also have an original RemoteLinc and I now get a message: Cannot Communicate With RemoteLinc. Please check connections.
Does anyone have any suggestions?
Tom
Are you putting the devices into linking mode before attempting any communication and selecting the correct Device Type entry from the pulldown?
If in linking mode and the correct Device Type is selected move the RemoteLincs closer to a Dual Band device (not a SignaLinc).
Yes, for both questions.
I tried moving the RL2 closer to a dual band device but still no luck. ( I was previous ~ 30 feet away and now I tried about 2 feet away)
It may be an issue with my previuosly linked original RemoteLinc. I get the error message about cannot communicate with the RemoteLinc while trying to link the new RL2. Also, the original RemoteLinc still works as usual, controlling the lights I originally programed it to control.
Tom
tdmarra
It sounds like the old RemoteLinc has pending activity. Put it into linking mode(Dim/Bright butteons), right click the old RemoteLinc node and select Write Updates to Device. Once that activity is cleared up then trying linking the RemoteLinc 2 again.
Lee
Hi Lee,
That did the trick. Thanks so much!
Regards,
Tom
