Inquiry to find program
I have an elaborate setup and one of my scenes controls a waterfall. The waterfall is programmed to turn on every evening at sunset and off at 9:30 pm. This program works well. But every morning the waterfall turns on for about an hour. I'm sure that I wrote a program for that at one time because it fits into my personal schedure of when I would see it. However, I can't find the program that controls the morning waterfall. Is there a search function that would call up all programs that a device is controlled with?
Hi Mitch,
Yes, Admin Console >Programs > Details. Then right click on any program or folder and select “Find/Replace.†Then in the popup window select “Insteon†or “Scene,†whichever would apply. Then select the device or the scene the device is in. Then hit “Find.â€
Tim
This also works on the Programs | Summary page. Clicking Find after selecting the device to locate highlights all the Programs containing a reference to the device.
Haaa, great stuff, so many programs you can't even remember what you did.
I have this problem with my Elk programs since it has no folder architecture to organize nor can you even give the programs names.
I might suggest you try creating a folder architecture in ISY to help you keep things a little more memorable.
The easiest way to find something like this might be to look at the Programs -> Summary Page and then sort by LastRunTime. That's what I do when I can't remember names.
