Elk-connected thermostats?
simonw
Michel and all,
Installed 3.1.12 and the Elk module; figured out you need to save the alarm code with the config in order for the zone etc. info to populate, etc.
The long-awaited and much discussed Elk module looks awesome, thank you very much!
Obviously I have a ton to learn, but am I right in thinking there is currently no way to work with Elk-connected thermostats? I have a couple of hard-wired RCS thermostats that the Elk can control. I just want to update the heat set point based on some program. Maybe there's a work-around setting Elk outputs from the ISY and having Elk rules react by changing the thermostat ... but be much nicer to have proper thermostat control right in the ISY. Any hope of that in some upcoming tweak? Otherwise I'll get on the hunt for a workaround ...
Congratulations again,
Simon
