'Else' after Repeat
After this finishes looping 10 times, shouldn't the 'Status Indicator' turn off?
X10 'G15/Dim (15)' is Received
Set '-Status Indicator (Ent. Ctr.)' 40%
Repeat 10 times
Set '-Fireplace' Off
Wait 10 minutes
Set '-Fireplace' On
Wait 20 minutes
Set '-Status Indicator (Ent. Ctr.)' Off
Jim,
This is similar to a thread that Chris Jahn had posted elsewhere (thanks again Chris).
Try putting a "run program XX" after the last wait in your "then". Looping back through the program should evaluate to the "else" (X10 Code not received) and turn your status indicator off.
IM
Jim,
IM
IndyMike,
I assume you meant to run this program? It seems like that would just make it loop forever, and when I tried it, it does. I just want it to repeat the on/off cycle ten times and then turn off the indicator, unless it is stopped by another program, which works.
thx.
Wow Jim,
As you already know - I was way off base. I had thought you were using a time base trigger and totally missed the repeat loop.
In the future, I'll try not to make posts when it's after my bedtime.
I know the feeling, believe me! And especially after 11 on Saturday night, with the frustrating realization that, once again, I have not won the PowerBall lottery. Oh well . . . . :cry:
I really don't understand why it shouldn't work. When it finishes repeating, it should run the else. It's really pretty simple.
Jim,
I believe the issue is that the "If X10" condition is a trigger (similar to a Insteon Control). The else loop really doesn't apply here.
If there were a X10 "status" trigger (doesn't exist) your else would execute.
I'm still playing with the program call trying to "force" the else loop. The following does execute the else (and sets the program status to false) once the then is completed. The problem is, the X10 off command isn't executed. I'm scratching my head a bit on this end.
       X10 'A1/Off (11)' is Received
       Send X10 'I1/Off (11)'
       Wait  1 second
       Send X10 'I1/On (3)'
       Wait  10 seconds
       Repeat 10 times
          Wait  1 second
          Send X10 'I1/Dim (15)'
       Repeat 1 times
          Run program 'X10 Test' (Else Path)
       Wait  2 seconds
Jim,
I found a method for executing the "else" but it involves two programs -
Program Test1 - Triggers off the X10 off command and tests to make sure "Test2" is not already running (prevents re-triggering).
   And Program 'X10 Test2' is False
       Run program 'X10 Test2'
Program Test2: Turns on lamp I1 and dims through 10 steps. The else loop is forced which turns the lamp off. The conditional "If Program "X10 Test..." is required to allow access to the else path.
       Program 'X10 Test2' is True
       Wait  1 second
       Wait  10 seconds
       Repeat 10 times
          Wait  1 second
       Repeat 1 times
          Run program 'X10 Test2' (Else Path)
       Wait  10 seconds
If you're not concerned about re-triggering, you should be able to move your else action to the last statement in your then sequence.
Repeat 10 times
  Wait 10 minutes
  Set '-Fireplace' On
  Wait 20 minutes
Repeat 1 time
 set '-Status Indicator (Ent. Ctr.)' Off
 No actions
IM
Yeah, I thought about using two programs after your last post (didn't reply since I was out and it's a pain on the BB).
I'll give it a shot.
Actually, I'm not concerned about re-triggering, so the second one is perfect. I didn't realize that the first Repeat would only repeat 'between the Repeats'.
So I ended up with:
Repeat 10 times
Wait 10 minutes
Set '-Fireplace' On
Wait 20 minutes
Repeat 1 times
The only thing I added was the 'Fireplace OFF' so when it finished it will turn it off, which I didn't have before. It normally would not run the full 10 times, since I have this program being disabled if the fireplace is either turned OFF or ON.
