Quick programming question
I know that if you want a program to trigger on a switch being pressed ON or OFF you have to do the CONTROL test for ON and NOT OFF but does this apply to STATUS also.
If I want the following program to trigger when a light turns ON or OFF do I need the ON and NOT OFF to execute the Else statement.
if
Status BedroomLight is ON
then
Set LivingRoomLight ON
else
Set LivingRoomLight OFF
No, status change will cause the program to evaluate.
The program as you set up should work fine
