Venstar Thermostat Unknown Device
I'm trying to program my thermostat so I can have a schedule but I think since it is showing as unknown device I don't get the options that I'm supposed to. I can't check status of cool/heat nor set temp. Model # is 2491T1E
Any help would be appreciated...
What revision of firmware are you using with your ISY99i?
Support for the 2491T was added in Beta 3.1.6
If you need to update it. 3.1.14 is the latest and recommended.
viewtopic.php?f=25&t=7575
Make sure you follow all the manual update instructions.
Like Java Cache clearing.
Definately not beta, not current stable release I think
In the Administrative Console.
Help tab.
About choice.
Will tell you exactly what you are running along with other information.
Thanks, upgraded and it shows up fine now. Now to program a schedule
Whoa, major problem woke up this morning to try and create my thermostat program and every device shows no status or any info? Is this a bug, seems pretty major? I'm going to reboot but is this common?
