Problem with using Motion Sensor to control a switch
I am using the Motion Sensor to control a switch using ISY99 program.
If the rule said Set Scene 'Laundry Room' On, it does work. However if I change the rule to say Set Device 'Laundry Room' On, it works everytime. I used "scene test" and it is working fine.
Here is the Rule and Event log. 14.7C.1E is the motion sensor and 1B.46.16 is the switch.
NOT WORKING
       Control 'Laundry Room - Sensor' is switched On
Tue 12/27/2011 11:21:23 AM : [iNST-SRX    ] 02 50 14.7C.1E 00.00.01 C3 11 01    LTONRR (01)
Tue 12/27/2011 11:21:23 AM : [standard-Group][14.7C.1E-->Group=1] Max Hops=3, Hops Left=0
Tue 12/27/2011 11:21:23 AM : [  14 7C 1E 1]      DON   1
Tue 12/27/2011 11:21:23 AM : Duplicate: ignored
Tue 12/27/2011 11:21:23 AM : [iNST-SRX    ] 02 50 14.7C.1E 00.00.01 C3 11 01    LTONRR (01):  Process Message: failed
Tue 12/27/2011 11:21:24 AM : [  14 7C 1E 1]       ST 255
Tue 12/27/2011 11:21:24 AM : [iNST-ACK    ] 02 62 00.00.12 CF 11 00 06          LTONRR (00)
Tue 12/27/2011 11:21:24 AM : [  1B 46 16 1]       ST 255
WORKING
       Set 'Laundry Room' On
Tue 12/27/2011 11:17:24 AM : [iNST-SRX    ] 02 50 14.7C.1E 00.00.01 C3 11 01    LTONRR (01)
Tue 12/27/2011 11:17:24 AM : [standard-Group][14.7C.1E-->Group=1] Max Hops=3, Hops Left=0
Tue 12/27/2011 11:17:24 AM : [  14 7C 1E 1]      DON   1
Tue 12/27/2011 11:17:24 AM : Duplicate: ignored
Tue 12/27/2011 11:17:24 AM : [iNST-SRX    ] 02 50 14.7C.1E 00.00.01 C3 11 01    LTONRR (01):  Process Message: failed
Tue 12/27/2011 11:17:25 AM : [  14 7C 1E 1]       ST 255
Tue 12/27/2011 11:17:25 AM : [iNST-ACK    ] 02 62 1B.46.16 0F 11 FF 06          LTONRR (FF)
Tue 12/27/2011 11:17:25 AM : [iNST-SRX    ] 02 50 1B.46.16 19.71.B3 2B 11 FF    LTONRR (FF)
Tue 12/27/2011 11:17:25 AM : [standard-Direct Ack][1B.46.16-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Tue 12/27/2011 11:17:25 AM : [  1B 46 16 1]       ST 255
Tue 12/27/2011 11:17:27 AM : [iNST-SRX    ] 02 50 14.7C.1E 19.71.B3 43 11 01    LTONRR (01)
Tue 12/27/2011 11:17:27 AM : [standard-Cleanup][14.7C.1E-->ISY/PLM Group=1] Max Hops=3, Hops Left=0
Tue 12/27/2011 11:17:27 AM : [  14 7C 1E 1]      DON   1
Tue 12/27/2011 11:17:27 AM : [iNST-ACK    ] 02 62 1B.46.16 0F 11 FF 06          LTONRR (FF)
Tue 12/27/2011 11:17:27 AM : [iNST-ACK    ] 02 62 1B.46.16 0F 11 FF 06          LTONRR (FF):  Process ACK: duplicate ignored
Tue 12/27/2011 11:17:28 AM : [iNST-SRX    ] 02 50 1B.46.16 19.71.B3 2B 11 FF    LTONRR (FF)
Tue 12/27/2011 11:17:28 AM : [standard-Direct Ack][1B.46.16-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
pc8888
RF devices are somewhat unique in that they send 4 messages when motion is sensed rather than the 2 normally associated with a Scene On (Motion On). Based on the Not Working trace it looks like the motion sensor was still sending part of the motion on sequence when the Scene On from the Program was issued. Try adding a 1-2 second Wait before issuing the Set Scene On in the Program.
Lee
:D:D:D
The "wait" does help! Thanks Lee.
