IOLinc & Low Voltage Probe (8015)
OmegaQuest
That is how my little tester was assembled.
Nothing more than a 1/8" stereo jack mounted on a small scrap enclosure.
With three wires soldered to it. Then I used the three wires screwed in to the I/OLincs terminal block.
Radio Shack even makes an 1/8" In Line Stereo Female Jack. 274-274 set of two. On mine copper tab is Tip and Silver tab is Ring.
You could solder wires to one. Then make sure the tip connected to Sensor and the ring to +5.
If you decide to just cut the plug off. The Red in the cable is sensor and the White was the +5V.
If possible I would make an adapter and not cut the plug Off. That way you could still return it if needed. As I was also not impressed with the way the Input Voltage was handled.
Link to comment
Glad it worked for you.
You may want to connect a diode in series with the Black/White Input wire. Band end to the Black/White wire. If your input is AC. I don't like putting too much reverse voltage on the OptoCouplers input.
A 1N4002 or 1N4003 would be a high enough reverse blocking voltage.
Link to comment
