KPL question
Hi all,
I installed an 8 button KPL and button B is for a set of under counter LCDs on an Appliancelinc.
Button B is set as a controller of and responder to the Appliancelinc.
When the lights go off by timer or manually by Mobilinc Pro, the B button stays lighted. I was under the impression that the light on the button should go off.
Do I need to edit something in the ISY99i programming or is this normal.
Thanks in advance!
This is normal. Instead of operating on the device itself (keypad B) do your operations on the scene you created that liked the two devices. Operating on the 'scene' will give the behavior you want.
Best.
Bill
