Sort My Lighting by Name?
SteveSBE
The My Lighting window does not sort by name when I click on the Name heading in the right side of the window. Is there a problem with that? Steve
It should.
Try logging off and rebooting the computer.
Check to make sure your ISY firmware level and Java control panel are using the same firmware version. Clear your Java cache and reload the java console.
Try rebooting ISY.
Try updating your firmware.
Now I am out of ideas.
It doesn't. I've done everything you suggested and it still does not sort properly. I created a small image here http://screencast.com/t/pGzGAjousnp as an example. The funny thing is that the first 1.5 pages (about 75 lines) sort OK and everything after that does not sort correctly.
I also just found out that if I sort the "Type" first and then the "Name" it does better however "Roof..." is sorted before "rem..."
Steve
