February 2, 200818 yr I'm using the newer KPL's (v1.65) which allow the KPL primary load to be controlled from a secondary button on the same KPL, but with on-level etc. different to the local on-rate. I just also bought a new ISY99, but I notice that the ISY doesn't support this feature yet (firmware 1.0), or indeed any linking between KPL buttons. Any ideas what firmware rev will add support for linking secondary buttons to the primary load, and when we can get our hands on it?
February 2, 200818 yr Hey Andrew - If you check this thread: http://forum.universal-devices.com/viewtopic.php?t=769 ..you'll see it's a listed feature for the upcoming v2.7 firmware. A beta for this firmware should be released soon. It's awfully quiet on these forums, which usually means they are hard at work!
