Everytime I sign into ISY I get this error message
Everytime I sign into ISY I get this message
Whats up with this?
easytim
The Start Linking process was initiated where the PLM and ISY is listening for devices to identify themselves and the Finish button on the Start Linkiing popup was not clicked to complete the process.
Reboot the ISY.
If the Start Linking poipup did not display to begin with check the Current State column. This column displays the current on/Off state of devices. If this column is completely blank something is blocking the data being pushed from the ISY to the Admin Console. When the Admin Console is started and thie column is completely blank the Start Linking popup does not appear. No function in the Admin Console should be initiated when the Current State column is blank for all devices. Exit the Admin Console and start it again. Normally the Current State column will be populated the next time.
Lee
