User Manual for ISY994i IR PRO, and PLM question.
I don't see a downloadable document available for the ISY994i/IR PRO. I was only able to find the isy99_userguide.pdf.
Does this document cover all of the models?
I just ordered the ISY994i/IR PRO. It appears that I'll need to purchase a "few" other things to get started.
The information available on the site, and in the document, indicate that I'll need to purchase the 2412S or 2413S PLM. I assume that also applies to the ISY994i/IR PRO.
Between those two PLMs are there any advantages? Which is the best option? I do have power supplies, so that isn't an issue.
Can I do better with something else?
Thank you.
The 2412S PLM is no longer being sold by Smarthome. The 2413S PLM does not provide 12V DC as the 2412S did. Therefore you will need an external power supply for the ISY in addition to the 2413S PLM..
Since you did find the users manual.
You probably have the link to the wiki but if not….
It has many tips and added things not in the manual itself.
Thank you both for the information!
