How do I get the Elk and ISY together?
sanders2222
I recently installed the M1G and have set up area and zone information. I then tried to link my ISY to the M1XEP entering the IP address, port 2101 and 6 digit access code displayed on the RP software account page. I saved the settings but, aside from saving information on the Config screen, nothing seemed to happen.
The refresh Topology button does not seem to do anything. None of the security information from my ELK appears under the module tab and the Elk Arm Stay and other buttons don't seem to do anything. What am I missing?
Note: When I used port 2601 in the ISY Config tab, my XEP goes into a continuous re-boot loop and knocks out any network connection to the M1G.
I have enabled 2101 as a Non-secure port in the RP M1XEP setup tab. I changed the RP Access code to my User Code and all boxes under User Authorizations are checked (though I thought I read somewhere never check the Access box).
I've verified there are no conflicts between my RP screen settings and the ELK. When I saved these settings in the ISY, the Admin Console locks up every time I click on the ELK module tab! Task Manager could not end it. The only way I can close the Console when it locks up is to log off my PC user account.
Even though the ISY seems to lock up, the RP software seems to connect just fine. After some time, the Console was activiated and now there is some data that shows in the Elk module tab, but not much. All 5 areas show up in the upper half but if I arm an area, nothing on this screen changes. Nothing is listed in the lower half and the ELK buttons along the top do not seem to do anything.
I just knew I read that someplace (duh). I unchecked the Access box and saved everything.
If I click on the ELK module tab or topology button, the Console locks for several minutes and I am unable to use it to do anything during that time. When it comes up, there is no change to what I can do or see. 5 areas show up but I deleted 2 of them. So it would appear this is not current information stored in the ISY.
As a side note, I have been able to use the RP but haven't been able to disarm the system from the keypad.
Problem Solved!
OK, it looks like my problems were related to the old bootware/firmware versions in my M1XEP. It took a while to sort that out but once I did, I followed the update procedures and now have 1.2/1.3.28. The RP has been connecting as it should and now the ISY shows my information under the ELK module tab, plus it's reporting the armed status and areas show in the pulldown.
      37.6k
      376.3k
