I'm using the following code to automatically turn off a light after a set period:
       Control 'Downstairs / Stair.Light' is switched On
    Or Control 'Downstairs / Stair.KP.Down Garden Lights / Stair.KP.A.Staircase Light' is switched On
       Set Scene 'Downstairs / Scene:Staircase Light' Fast On
       Wait  2 minutes
       Set Scene 'Downstairs / Scene:Staircase Light' Fade Down
Questions:
- Is this code correct?
- Occasionally the light does not turn off. Aside from the two controls in the if clause, there are no other buttons to turn on the light. I've also checked the error log - it does not show any communication errors (only entries are DHCP renewals). Any ideas for getting this to work reliably?
- Is there a way to print a message from the program to the log (or other file)? This could be very handy for debugging. In fact, how does one debug these programs?
Many thanks,
Bernhard
A Fade Down (or Fade Up) is half of the expected sequence which is the functional equivalent to pressing and holding the Off button/paddle. When done from a device the sequence always ends with a Fade Stop when the button/paddle is released. This is missing in the posted example. Don't know if a Fade Stop will resolve the problem but it is necessary to complete the Fade process in each device.
Add a Wait of some seconds to allow the Fade Down to run its course and then issue a Fade Stop.
I wrestled with this same thing recently, here is what I ended up with and it works flawlessly:
Control 'Staircase' is switched On
Or Control 'Staircase Slave' is switched On
Wait 30 seconds
Set Scene 'Staircase Pair' Fade Down
Wait 3 seconds
Set Scene 'Staircase Pair' Off
Set 'Staircase' Off
Set 'Staircase Slave' Off
LeeG helped a lot.
I also added this separate program to keep the lights on:
Control 'Staircase Slave' is switched Fast On
Or Control 'Staircase' is switched Fast On
Set Scene 'Staircase Pair' On
Another cool thing is to lower the brightness at night.
Skripo
Thanks for posting a working example.
Boser
The posted example issues a Set Scene Off followed by Direct commands to each Responder to turn Off. This should not be necessary and will be cumbersome if several Responders are in the Scene. I suggest trying it the way Insteon protocol is expecting it to be done with a Fade Stop.
       Wait  2 minutes
       Wait 4 seconds
       Set Scene 'Downstairs / Scene:Staircase Light' Fade Stop
