Upgrade to ISY 99i from ISY 26
Hi Guys;
Just got my new ISY 99i (thank you again Michel and Rand for the over and above service, I promised I wouldn't get misty, :lol: )
I noticed it doesn't have a power supply. I believe my PLM is the 2413S but will have to check when I get home.
Can I use my power supply from the ISY 26? (Just checking so I don't fry anything.)
If not, what amps, voltage, centre negative or positive, should I get?
Also, since I've had the ISY 26, I've only been able to update to 2.7 (ish) Does this ISY ship with the latest version or should I update when I get it?
Do I set it all up and then update, or update the version first then set it up with my system?
Drew
