Having fan stay on after heat / cooling shuts off
Hi,
I have a Venstar thermostat with the Insteon module and a 99i. What I'd like to do is have a program that when the heat / cool of the thermostat goes off (temp has been reached) the fan then comes back on for 15 minutes to help even the temperature around my house.
This will be my first program with the 99i, so I'm not sure where to start.
Thanks in advance,
Shawn
This will work for heat. You can add another one for cool.
This will wait 1 1/2 mins after heat comes on before fan comes on (don't like blowing cool air).
This will continue to run fan for 15 mins after heat is off.
       Control 'DEVICES / THERMOSTATS / HU TS (Heat Control)' is switched On
   And Control 'DEVICES / THERMOSTATS / HU TS (Heat Control)' is not switched Off
       Wait  1 minute and 30 seconds
       Set Scene 'LIVING ROOM / LR Ceiling Fan' On
       Wait  15 minutes
       Set Scene 'LIVING ROOM / LR Ceiling Fan' Off
It isn't a separate fan, but rather the blower on the central air / heat unit. This is what I came up with and seems to work ok.
       Control '14.21.07 - Heat Control' is switched Off
    Or Control '14.21.07 - Cool Control' is switched Off
       Wait  1 minute
       Set '14.21.07 - Main' Fan On
       Send Notification to 'Default' content 'Fan On'
       Wait  15 minutes
       Set '14.21.07 - Main' Fan Auto
       Send Notification to 'Default' content 'Fan Off'
Looks to be working ok for now.
Shawn
