Can mControl work with ISY ?
I'm really happy with the automated functions programmed into isy, but I don't like having to manually intervene.
For example I have a "vacation mode" variable that I change from a value of 0 to 1 to invoke automatic light timers throughout the house. What I'd really like to do is change this value by running a command from an external program such as mControl.
I've made some progress with mControl and would like to explore the possibilities. I hope I am not offending the isy community by trying to use mControl as a GUI for isy.
I was afraid someone would say that. Is there a good link on using rest in this forrum ?
Okay I see the generic command line I need:
/rest/vars/set///
In my case = 2, = Vacation.Mode, = 1
Now what is the syntax to send to the isy99i device = 192.168.0.xxx
with user = admin
and password = pass
http://admin:pass@192.168.0.xxx ?
I’m not enough of a network guy to understand what affect the port number and userid are having. Can you try the simple forum I posted (with your local IP address) into a browser command line and confirm the basic REST part is working. Someone with more network savvy than I will have to pick up from there.
satwar, just a thought. What type of browser are you using...Windows IE9 will not allow user/password in the address.
Sorry for the delay but the rest part is working. I must have made a typo. Unfortunately I am still getting the confirm userid & password dialog box.
Yes I see the problem about ie9, but I'm using Firefox. Microsoft does offer a patch to allow userid:password in the http path.
It's working, after I used the microsoft fix 50642. I'm stuck with ie because I'm issuing the commands from a whs v1. It's using ie7, which also has the problem of not accepting Userid:Password@IPaddress in the http:// path.
Thanks all for the help. I didn't expect results so soon.
