Programming help for newbie please
Hi, I am new at programming and I would like some help please.
I have an appliance linc (called Crawlspace Pump) that I want to reset (turn off then turn back on) every 3 hours during the day, and every 6 hours during the night.
Here's what I have done so far.
From Sunrise
To Sunset (same day)
Set 'Crawlspace Pump' Off
Wait 5 seconds
Set 'Crawlspace Pump' On
-No Actions
How do I program in a loop that will repeat the "then" commands every 3 hours?
"How do I program in a loop that will repeat the "then" commands every 3 hours?"
From Sunrise
Repeat Every 3 hours
Wait 5 seconds
Because the Set 'Crawlspace Pump' On might not execute in the last cycle depending on the time between Sunrise and Sunset that same statement can be added to the Else clause. This insures when Sunset occurs the Pump is turned back On
