Problems with Admin Console
I tried searching this problem in the forums and wiki but either couldn't find it or missed it. I just received my device and I'm having an odd problem with the ISY Admin Console in that any changes I make are not reflected.
For example if I add scene or add new insteon device it will let me name/put in address I then hit enter and nothing happens. To see the new scene/device I have to completely exit from the admin console and reload it. Additionally it is asking me to re-authenticate every few minutes. I'm not sure whether that is a related problem.
I've tried different firmware versions, flushing the java cache each time, and it is currently running v.3.1.17. I've tried factory reloads with no change. This is very frustrating and I'm assuming not expected because it makes the device unusable to me.
Is Avast or Kaspersky being used?
Avast yes! Using a separate system not running avast has cleared up all my problems so far. Will resolve the problem with Avast. I assume it is a blocking issue I will need to add exception for?
