Quite possibly the Dumbest Question..
What exactly is the difference between ON and FAST ON etc.. When should one be used instead of the other?
Duh, Thanks!
The Insteon On command turns a device On (usually). The On command specifies the specific On Level the device should turn On to. The Local Ramp Rate is respected by the On command. It is the equivalent to a single tap of the top of a SwitchLinc paddle.
The Insteon Fast On command turns the device On to 100% at a fast ramp rate. It is the equivalent to a double tap of the top of a SwitchLinc paddle.
