How to program KeypadLinc 2486DWH6
I just installed ISY99 to my system, I've been using Smarthome X10 devices throughout the house. In the last few years, I have been replaced bad modules to Insteon/X10 version.
I currently have HAI security panel, along with an ACT X10 coupler/repeater. With this new ISY99, I was able to get scenes created within the interface and it found the devices with their model #, very impressive.
I do have a question, all my Insteon KeypadLincs all show up like this:
Switch1
Switch1 - A
Switch1 - B
Switch1 - C
Switch1 - D
I have "Switch1 - A" linked to Switch2, so if I press "Switch1 - A", it will turn on "Switch2". Press again it will turn off "Switch2". Only issue I have is, if I press "Switch2" locally, the status on "Switch1 - A" is not being reflected.
Is that something I need to do when linking these devices? Or I need to write a program so it will update the status?
For programming a specific button, can I just assign say "Switch1 -B" to "Switch3" somewhere in the GUI? Rather than using the linking mode within the switches?
Much appreciate your help.
It sounds like "Switch1 - A" was added to the ISY Scene as a Controller and "Switch2" was added as a Responder. As a Responder "Switch2" does not control any other device. Remove "Switch2" from the Scene, adding it back as a Controller. That way either device will control the other. The ISY assumes a Controller is also a Responder.
I do not understand the question. If “Switch1 – B†is to control “Switch3†both devices should be added to another ISY Scene as Controllers like above.
Thank you, I'm starting to understand the logic, I must be in X10 for the longest time, can't really get a good grip on how to program these Insteon switches, even pairing I don't have much success between switches.
I've attached a screenshot of my lights and scenes so far, at the very top I have a KeypadLinc named:
Basement Ceiling Fixtures
Below that it shows 4 buttons
At the bottom I created a scene for Basement Ceiling Fixtures, then I added the switch below, as well as another Keypad button that I'd like to control the fixtures. Both are set as controllers, am I doing it right?
Or should I be doing something else?
Those Scenes look exactly right. With each switch/button added as a Controller the ISY cross-links them automatically so that each switch/button controls the load and the status LEDs stay in sync.
