Problems with control B2457D2 in a scene
I have 2 B2457D2 linked to my isy99. Both seem to work fine I can turn them both on and off within isy99. However if I put them in a scene they do not seem to respond even though it appear isy wrote the data to them.
I have other devices in a scene that have always worked fine.
The new LampLincs are I2CS devices which require ISY 3.2.4. Upgrade to 3.2.4. Be sure to clear the Java cache and use the URL for accessing the 3.2.4 Admin Console. After update go to Help | About and confirm the Firmware and UI lines both indicate 3.2.4.
Then Delete the LampLinc and add it back under 3.2.4.
I did this before posting :(.
UI and Firmware both read 3.2.4.
Should I remove the devices and scene and re-add them?
The LampLinc must be added to the ISY and the Scene created under 3.2.4.
Deleting the devices and scene then recreating them under 3.2.4 fixed it.
