February 10, 200818 yr Need some help configring scenes controled by 2, 6 Key KPL's. I have 4 kitchen scenes (Scene A - Scene D), controlled by 2 KPLs. The scenes operate correctly from both sources, except the scene states (as noted by the led) do not sync. Each scene is configured as follows: Both KPLS in AToggle Mode Within each Scene, the corresponding Scene Key are linked as CONTROLLERS on both KPLs All other KPL buttons configured as RESPONDERS within Scene (on both KPLs) All Buttons (Main, A-D) are in Mutual Exclusive Group Neither KPL has a load attached. Help appreciated! ps Using ISY-99i - IR PRO to configure.
February 10, 200818 yr All other KPL buttons configured as RESPONDERS within Scene (on both KPLs) I don't think that is correct. Try deleting all the buttons other than the controllers.
