OK to Enable / Disable Programs within programs?
I have a program that counts the number of days elapsed since I last replaced the furnace filter:
Time is 5:30:00PM
$FF_Days_Since_Furnace_Filter_Reset += 1
$FF_Days_Since_Furnace_Filter_Reset Init To $FF_Days_Since_Furnace_Filter_Reset
There is also a program the notifies me by e-mail / text message that its time to change the filter:
$FF_Days_Since_Furnace_Filter_Reset >= 40
Send Notification to 'Kevin MMS Alert' content 'Furnace Filter Days'
Send Notification to 'Kevin E-Mails' content 'Furnace Filter Days'
Run Program 'FF - Announce Filter Due' (If) ***more on this later***
I also have (had) a line in the Then clause that would announce through the whole house voice system "Please remember to change the furnace filter today."
Recently, I upgraded my alarm system to an ELK... so the ISY now "knows" if we are home or not based on this program:
Elk Area 'House' 'Armed State' is Armed Away
Or Elk Area 'House' 'Armed State' is Armed Vacation
$HA_Is_Home = 0
$HA_Is_Home Init To 0
$HA_Is_Away = 1
$HA_Is_Away Init To 1
$HA_Is_Home = 1
$HA_Is_Home Init To 1
$HA_Is_Away = 0
$HA_Is_Away Init To 0
I wanted to change the behavior of the filter program to - rather than just announce the message - announce it immediately if we are home, BUT if we are away, hold the voice announcement until we arrive home.
So... I wrote this program, which is normally left DISABLED:
$HA_Is_Home is 1
Resource 'Audio_Attention'
Resource 'Audio_Furnace_Filter'
Disable Program 'FF - Announce Filter Due'
Enable Program 'FF - Announce Filter Due'
It becomes ENABLED if the days since filter change is >=40 AND we are not home (the ELSE clause executes when the If is forces by the notify program).
Then, when we arrive home (and the Is.Home variable updates), this program executes, makes the voice announcement, then the program DISABLES its self.
Is there any issue (performance, reliability, etc...) with using programs to enable / disable each other (or themselves)?
So, when you change the filter how do you reset your counter? Manually via the Admin Console or do you have some other way?
Brian
I run a program via MobiLinc Pro on my iPhone. If I forget, I get another reminder the next day when I get home.
