Use TriggerLinc to flash KeypadLinc buttons?
Hi All,
I'd like to use some Triggerlincs to monitor my fence gates and if left standing open, the triggerlinc would flash a particular button on my 8 button keypads. Flashing a light will work as well but I think it would be cooler to just flash the button on the keypadlinc if possible.
A KeypadLinc button can be defined as a Responder to a Scene and turn the Scene On/Off at some appropriate rate. However, flashing for more than a few seconds puts a lot of Insteon traffic on the powerline which can interfere with other Insteon activity. Flashing/blinking is not recommended.
I agree with LeeG. I would not do this due to the amount of insteon traffic needed. However, if you insist, I suggest a program. The logic (if not exact language) would be:
if status gate is open
then
repeat
turn keypad on
wait a few seconds
turn keypad off
wait a few seconds
else
turn keypad off
Thanks for the comments, wonder if there is an Insteon module that has a flash mode? I seem to recall that this was possible with X-10 equipment.
I have not seen an Insteon device with flash/blink function.
Kind of Cheesy (but I'm from Wisconsin). Use an Appliance link with an LED of some sort plugged in that flashes (only thing I can think of is a flashing Christmas tree light). Make a simple program that monitors the TRiggerlinc, when gate open turn AL on. When gate closed turn AL off.
aLf
