Micro Modules in FCC Database
Brian-
Thanks for posting that.
I have reviewed a bunch of the docs at the FCC and I'm not sure I understand what these modules are for exactly. Looks alot like the Inlinelinc relay/dimmers to me. Not sure exactly what the extra light gauge wires are for. Maybe sense line(s) ?
These do look to be smaller than the Inlinelincs and I like the screw terminal idea for in-box installations. I was unable to find any load ratings in the documents available.
Any thought as to what these modules are intended for ?
-Xathros
Well if they are anything like the European X10 Micro Modules. They maybe able to use a push button on the switch plate the module is mounted under. Too toggle their state as well as be controlled by RF and Power Line commands.
Brian
That is what I took from the doc. The sense lines can be connected to either a single button which probably cycles On/Off or connected to two buttons which would act as On and Off.
Amazing how much speculation is generated by such little information
Interesting. I saw a separate off wire and an on wire in one of the docs.
I do like the fact that there appears to be a dry contact version.
