new dual band on/off switch in a scene
the new dual band on/off switch doesnt work in a scene for me running 3.2.6. is there a new update yet that may fix this?
I've not seen a report of a problem with the Dual Band SwitchLinc Relay. The device must be added to the ISY under 3.2.6 and Scene must be created under 3.2.6. Check Help | About to be sure both the Firmware and UI lines show 3.2.6. 3.2.6 is the latest ISY image.
What Scene problem are you having?
  • 1 month later...
i have linked the switch to a button on my 6kpl. when i turn it on via kpl, the light doesnt turn on. when i turn the light on, the kpl doesnt update. i have a timer to turn the scene on, it doesnt turn that light on, but turns others on.
Are the SwitchLinc and the KPL button linked as Controllers of the Scene?
When the KPL button is pressed On does the Admin Console show the SwitchLinc as On?
When the SwitchLinc is turned On/Off from the Admin Console device page does the SwitchLinc turn On/Off?
