Write / Append to file
NNilsen
I have an application that requires logging activity in plain text format to a log file.
I do not see such and action in programs
Example:
If - Insteon button "home" is pressed
Then - append to file occupancy.txt date() time() string("Home")
If - Insteon button "away" is pressed
Then - append to file occupancy.txt date() time() string("Away")
The file can be anyware that can be accessed IE: on an external network drive
I am currently sending an e-mail via ISY for external parsing
NNilsen-
I am using the network resources module to send to a syslog server running on my MAC. Also tested with a linux box. Not perfect but it works.
-Xathros
NNilson-
Here is the blurb on Network Resources from the UDI Website:
Network Module: host your own personal web site or 3rd party applications right on your ISY, control network-enabled devices through ISY programs (TCP/UDP/HTTP/HTTPS), turn on PCs using Wake On LAN
Generally speaking, anything that you can control from a browser, you could write a resource rule to control. It takes some research to figure out how to talk to certain devices but its usually not too difficult. You can use a program like Wireshark(Mac/Win/Linux) or EavesDrop (Mac) to "Sniff" the network traffic between your browser and the target device and then use the what you find there to build the rule.
Here is one of my syslog rules:
The network module also sets up a webserver on the ISY so you can host some basic web stuff on the ISY if you like.
-Xathros
