Switch Insteon Devices in ISY
I did some switching around of my insteon devices.
I had an outdoor appliancelinc on/off module controlling some landscape lights. I removed the module and instead am going to use it to control some holiday lights in the backyard.
For the landscape lights which used to be controlled by the above appliancelinc, I replaced the receptacle and wired-in an in-line linc.
How do I make all the changes in the ISY? The landscape lights were embedded in various programs and scenes...I don't want to have to go back and re-do each thing from memory. Is there a way to simply change the address of the insteon devices but instead use the same names?
There is a Replace xxxx with .... function but that is limited to devices of the same type. It will not Replace an ApplianceLinc with an InLineLinc. There is a Find/Replace function for Programs that may help. Go the Programs | Summary page. Right click and select Find/Replace. Occurrences of a specific device name can be located and if desired replaced with another name.
