How to set up ISY with new router...
I bought a new router and have it set up. I have connected mobile devices and PCs. I can't get my ISY to connect to it for anything. It is trying to use the following IP address xxx.yyy.2.114 which is what it used on the old router. The new router has a range of xxx.xxx.1.2 to xxx.yyy.1.254. So my old IP isn't in the new router's range.
It will not connect when I go to http://www.universal-devices.com/99i
How do I get this straight? Thanks!
Ok. I rebooted the ISY and it picked a different IP addy and seems to be working. I'm not sure if it will rotate IPs or if it is static though.
If you have DHCP turned on with the ISY, which it sounds like you do, then it could get a new IP address if you lose power and things restart. You can turn off DHCP on the ISY and hard code an IP address in, and all of the other particulars, or you should be able to use the ISY MAC address and hard code it into your router to assign an address outside your router DHCP range. You might want to change your range to 192.168.1.10 to 192.168.1.254 so you have 9 addresses you can hard code.
