Issue with program not repeating at specified interval...
Here is my program...
  From 6:00:00AM
  For 11 hours
  Repeat Every 1 hour
     Resource 'Elite TV - AV Mode - ISF Day'
     Wait 30 seconds
     Stop program 'AV Mode - ISF Day'
When this program runs at 6AM, it runs correctly but the 'Next Scheduled Run' show 5:00:00PM. It should show and run the program again at 7:00:00AM?
ISY99 - v3.3.2 (I was on v3.2.6 before today and it exhibited the same behavior)
The next scheduled run time reflects the end of the time range (+11 hours) when the Program will be triggered, driving the Else clause. What does the Activity column show when the Program is running?
EDIT: the Repeat statement does not cause the Program to be triggered again as the Program would start over from the beginning of the Then clause, not the beginning of the Repeat loop. The Activity column would be expected to show Running Then while the Program is waiting for the Repeat time interval to elapse.
Oh I see, thanks for the explanation of how the 'repeat' function works in a program. I know how to set up the program now.
Thanks LeeG!! :D
