Mobilinc cant connet
Mobilinc has been working great until now. The power went out briefly today and since then I keep getting a connection error. I tried syncing but I still get the connection error. Thanks
Do you connect directly to your ISY or through the MobiLinc Connect service?
If direct, please double check the IP address information in MobiLinc and make sure that matches your ISY's actual IP address after it came back up from the power loss. It's very likely that the IP address changed.
Wes
