Where's the login screen and the Elk Module
I'm on Mac OS 10.8
ISY 99
just bought the Elk Module
was logged in and it asked to restart in order to install new module. Did this a few times as the new module wasn't installing. Then I tried to log in and while the admin console comes up the login box no longer does (and no idea if the Elk module was installed)
SOLUTION TO LOGIN SCREEN - PLM came unplugged :0
Now the issue is that I can't get the Elk module installed - I follow instructions and when I reopen the device console - still no Elk module
Thank you for any suggestions / help
I think I may have found the issue with adding the Elk module...the device console was at version 2.70.
So I have now tried to update automatically to 3.2.6...however...I'm now over an hour into the process and my screen is still showing 0% on the progress bar.
Help / suggestions?
Got in touch with support (they are fantastic!) and the issue was that I was at such a low firmware that it had to be updated in smaller increments, so went from 2.7.0 to 2.7.15 to 2.8.16 to 3.2.6 and all was fixed.
Glad you got it working.
I agree the support from UDI should be a model for other companies to follow.
