Full remotelinc support?
I can't figure out how to get Isy (3.3.4) to link a device to a remotelinc's all on/off buttons without adding it to one of the normal scene buttons. Am I missing something, or does Isy just not support this? I could definitely do this before I started using Isy if I linked the devices manually.
Also, Isy seems to list options to enable/disable the beep and led for remotelinc 2 but not for remotelinc 1. Again, am I missing something or is this unsupported?
No you are not missing something.
As far as I have seen you can not link anything directly to the All On and All Off buttons.
I have used a manual linking on my original hardware RemoteLinc to a Insteon Device and it took.
Later Remotelinc firmware may have corrected this from happening.
That said the ISY controller does not know about this link and will gladly overwrite it if you add something new through My Lighting.
