Program control of KPL buttons
Is it possible to control KPL buttons other than Main from a program? Specifically I need to be able to turn button C (or D, etc) on and off directly from a program.
mike
I believe that you need to create a single-device scene, and control the scene from the program.
Secondary KeypadLinc buttons have to be controlled with an ISY Scene. Define a Scene, adding the KPL button as a Responder. Turn the Scene On/Off from the Program. The Insteon Direct command does not have a placeholder for a button number making it impossible to control a Secondary button directly.
Thanks, that did the trick.
mike
