Network Resource To E-Mail IP Camera Images on Motion
\n";
print "Executing snapshot.pl\n\n";
print "Capture $image_count images spaced $image_spacing seconds apart:\n";
#Define image capture start and end times
my $startTime = time;
print "\tCapture start time is $startTime\n\n";
#Create new directory for image set
my $new_directory = "$out_dir/$startTime";
print "New Directory: $new_directory\n\n";
mkdir $new_directory;
#Reset image index (counter)
my $index = 0;
#Store the first expected image filename - will be used to determine if camera responded with a valid image
$first_image_file = sprintf("$new_directory/image-%s-00001.jpg", $startTime);
print "\$first_image_file=$first_image_file\n\n";
#Loop for desired image count, capturing and saving camera snapshot images
print "--------------------------------------------------------------------------------\n\n";
while ($index < $image_count)
$index++;
print "Time is " . time . "\n";
#Set full image filename
$output = sprintf("$new_directory/image-%s-%05d.jpg", $startTime, $index);
#Retrieve snapshot image from camera
my $result = `/usr/bin/wget -O $output $cam_url`; #Retrieve image from camera and save to file
print "Saved $output\n\n";
#Wait until next snapshot time
sleep($image_spacing);
if ((-e $first_image_file) and (-s $first_image_file)) #check for existence and size of expected camera image file
#Since a non-zero sized file was created (from the camera), build e-mail with images attached
#Set up e-mail parameters
$subject = "Driveway Motion Detected...";
$body = "Captured these images:\n";
#Build attachment file list from all file names in the output directory
@files = <$new_directory/*>;
foreach $file (@files)
$attachment_files .= "$file,";
$attachment_files =~ s/,$//;
print "Sending e-mail...\n";
print "\t\$mail_host=$mail_host\n";
print "\t\$mail_user=$mail_user\n";
print "\t\$mail_pass=$mail_pass\n";
print "\t\$subject=$subject\n";
print "\t\$body=$body\n";
print "\t\$attachment_files=$attachment_files\n";
else
#No file, or a zero sized file was created. Build FAILURE e-mail
#Set up failure e-mail parameters
$subject = "Driveway Camera FAILED...";
$body = "Camera did not produce requested images.\n";
#Send e-mail with parameters defined above
my $mail=Email::Send::SMTP::Gmail->new ( -smtp=>$mail_host,
-login=>$mail_user,
-pass=>$mail_pass
$mail->send ( -to=>$mail_recipient,
-subject=>$subject,
-verbose=>'1',
-body=>$body,
-attachments=>$attachment_files
$mail->bye;
print "
  • 4 weeks later...
Hi,
Would you be able to share your ISY network resource program?
The network resource is just a simple GET to my web server:
Server:192.168.xx.yy
Port:zz
Resource:
/cgi-bin/snapshot.pl
Sent from my iPad using Tapatalk HD
I am trying to get my head around network resources. So the simple Get just requests a page from the server, and your page happens to be a perl script that gets run?
That being similar in concept to a wget command from the command line.
So by theory, we could have any perl script called because the webserver can run it when requested by a page hit.
Your server is running Apache, or maybe misterhouse with it's little webserver or ??
Always been a bit concerned with security with a webserver running because they just seem to have lots of open vulnerabilities.
The web server is on my internal network. It in not open to anyone outside the house. You must already be on my network.
Yes. You are correct. Any perl script can be kicked off via network resource using this method.
My server is running Ubuntu, and apache.
